pfSense settings
- pfSense settings
pfSense settings
14-12-2013 4:30 PM
Hi everybody!
I have Plusnet FTTC broadband and I want to change the supplied router to a pfSense box, I was wondering if anyone could tell me which connection settings I need to use. The ones on the website dont seem to match up with the options available!
Message 1 of 3
(1,254 Views)
2 REPLIES 2
Re: pfSense settings
14-12-2013 4:50 PM
You will need to configure it's WAN interface for PPPoE using you plusnet username & password. This should help http://www.interspective.net/2012/05/pfsense-initial-configuration-adsl-wan.html
Message 2 of 3
(859 Views)
15-12-2013 7:09 PM
Thanks! Something I must have done while setting it up must of screwed up somewhere. A fresh install and that guide worked first time! Now to have a play (and probably break it again! :))
Message 3 of 3
(859 Views)
