perfect connection gone bad
- perfect connection gone bad
Re: perfect connection gone bad
05-11-2010 1:32 PM
Got a brand new filtered one and not a hint of any noise.
DSL Connection
Link Information Uptime: 0 days, 1:07:11
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 936 / 9,408
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 34.62
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 10.0 / 19.5
SN Margin (Up/Down) [dB]: 22.0 / 13.5
Thank you support for all your help and especially Jojo.
One more thing please could you match my profile with BT's please currenly on 5000Kbps BT at 6500Kbps
Is it to early to turn interleaving back off?
05-11-2010 1:39 PM
Just brought the PN profile up to 6500 now. I'm afraid the line still isn't looking 100% so wouldn't turn off interleaving just yet. Have you been rebooting or turning the router off at all today?
Jojo
05-11-2010 1:49 PM
I will wait a while for the interleaving then. thanks again
05-11-2010 2:30 PM
These are the connections for today:
Jojo
05-11-2010 2:37 PM
06-11-2010 7:11 AM
DSL Connection
Link Information
Uptime: 0 days, 0:23:34
Maximum Bandwidth (Up/Down) [kbps/kbps]: 936 / 9,440
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 66.09
SN Margin (Up/Down) [dB]: 22.0 / 13.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 41 / 0
Loss of Signal (Local/Remote): 1,179,636 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1,179,711 / 0
FEC Errors (Up/Down): 0 / 262
CRC Errors (Up/Down): 5 / 0
HEC Errors (Up/Down): 0 / 0
Noise has returned, BT still at 6500 but PN at 5000.
"Loss of Signal (Local/Remote): 1,179,636 / 0"
Waiting to see if my profile will drop now.
16-12-2010 4:23 PM
Back down to a 135k Profile
Whats going on?
16-12-2010 4:26 PM
Although having said that, after all the problems we've been having with our connection, we've only been disconnected about twice in the last couple of months. I honestly think it's something to do with the weather. It seems that whenever it's really cold, we suffer from fewer disconnections.
16-12-2010 4:55 PM
Hoping it will rise later on.
Uptime: 0 days, 0:58:16
Maximum Bandwidth (Up/Down) [kbps/kbps]: 936 / 8,480
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 11.71
SN Margin (Up/Down) [dB]: 22.0 / 12.5
16-12-2010 5:11 PM
BT profile down to 135k, probably down to some disconnects. sync is steady 7616 so if it stays stable it will pick up.
Jojo
17-12-2010 1:47 PM
Having lots of problems again dont want togo backwards.
Uptime: 0 days, 2:34:41
Maximum Bandwidth (Up/Down) [kbps/kbps]: 932 / 8,608
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 6.16
Loss of Signal (Local/Remote): 262,157 / 0
Error Seconds (Local/Remote): 327,696 / 0
FEC Errors (Up/Down): 1 / 684
CRC Errors (Up/Down): 6 / 9
HEC Errors (Up/Down): 1 / NA
17-12-2010 1:53 PM
17-12-2010 2:02 PM
Although you can refer to the closed ticket we will still have to conduct tests again. I imagine the first instance would only probably be helpful once noticeable similarities started to become apparent. The first thing we need to though is to troubleshoot your dropping connection. Are you in the test socket? have you been using extension sockets/cables? have you tried a replacement filter?
Jojo
17-12-2010 2:28 PM
2) New Drop Wire, Exchange Work Etc
3) New Modem ( Thomson V8)
4) New Filtered Master Socket ( Plus RF3 Filter )
5) Engineer been out 3 times last visit was told it could be a faulty port.
I feel like everything that can be done has already been tryed.
Problem is not in my home.
Cracking on the line causes It to drop
Thanks Jojo for your help.
17-12-2010 2:46 PM
