peak latency
- peak latency
peak latency
23-05-2013 9:11 PM
Has it returned for anyone else?
starting to see quite high ping in the evenings again on ptw-ag01
usual ping 12-16ms now 64ms
and speed is all over the place
[img]http://www.thinkbroadband.com/ping/share-thumb/99162f576da26a52e91fb7e505d99e5b.png>
Message 1 of 5
(797 Views)
4 REPLIES 4
Re: peak latency
23-05-2013 9:19 PM
Ive been experiencing this after 8pm for two days now.
Message 2 of 5
(494 Views)
Re: peak latency
23-05-2013 11:04 PM
For me nearly every night for the past month Jitter between 8pm and 11pm or there about , but throughput not always affected, tonight it has been significantly affected mainly the downstream, fluctuations to as low as 40mbps so around 35-40% PTW-AG03, also Sunday evenings can be quite bad too
Message 3 of 5
(494 Views)
Re: peak latency
23-05-2013 11:10 PM
Quote from: HNKS Ive been experiencing this after 8pm for two days now.
Same for me. Speed anywhere between 0.45 and 7
Message 4 of 5
(494 Views)
Re: peak latency
24-05-2013 9:22 AM
Hmm. Every night?
Can you guys run some speed tests during the day, and then one after 8pm and post the results here. Some ping tests at those times would be good too.
I'm not aware of any congestion/performance issues right now; we've got loads of WBC bandwidth and the kit is fine. More info will help!
Kelly Dorset
Ex-Broadband Service Manager
Message 5 of 5
(494 Views)
