peak latency
danger11
peak latency
Has it returned for anyone else?
starting to see quite high ping in the evenings  again on ptw-ag01
usual ping 12-16ms now 64ms
and speed is all over the place
[img]http://www.thinkbroadband.com/ping/share-thumb/99162f576da26a52e91fb7e505d99e5b.png>
HNKS
Re: peak latency
Ive been experiencing this after 8pm for two days now.
deathtrap
Re: peak latency
For me nearly every night for the  past month Jitter  between 8pm and 11pm or there about , but throughput not always affected, tonight it has been significantly affected mainly the downstream, fluctuations to as low as 40mbps so around 35-40%  PTW-AG03, also Sunday evenings can be quite bad too
loftybloke
Re: peak latency
Quote from: HNKS
Same for me. Speed anywhere between 0.45 and 7
Fixes: 5
Re: peak latency
Hmm. Every night?
Can you guys run some speed tests during the day, and then one after 8pm and post the results here.  Some ping tests at those times would be good too.
I'm not aware of any congestion/performance issues right now; we've got loads of WBC bandwidth and the kit is fine.  More info will help!
Kelly Dorset
Broadband Service Manager
