pcl-ag03.
rongtw
Fixes: 12
pcl-ag03.
Shocked was on  pcl-ag03. tonight , for some reason while playing me game , the connection went ----------WEST  Sad did anyone notice anything ?Huh
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: pcl-ag03.
We'll look at this tomorrow morning to see if we can spot anything :/
Chris Pettitt
Cloud Environments Engineer
wo0x
Re: pcl-ag03.
Which gateway
Sorry, the tool currently could not identify your gateway; this does not mean that anything is wrong with your connection.
Anyone else been getting this lately?
Re: pcl-ag03.
I think there's been some new gateways activated recently and the tool probably hasn't been updated to recognise them.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Fixes: 71
Re: pcl-ag03.
The tool doesn't need updating to recognise the new pcl-bng02 gateways. What does need doing is for Plusnet to change the reverse DNS entries for these gateway IPs to identify them as such.
David
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: pcl-ag03.
I've asked Dave to take a look to see if we can spot anything.
Chris Pettitt
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: pcl-ag03.
We can't spot any oddities. We'll keep an eye on this though.
Chris Pettitt
rongtw
Fixes: 12
Re: pcl-ag03.
Chris will stay on this gateway to see how things go tonight  Wink
if no better will Hop to another
Terranova667
Re: pcl-ag03.
I'm on pcl-ag05 and i have seen my Latency increase from it's normal 15ms to around 18ms you see the increase in my TBB graph below happened around 3am this morning
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: pcl-ag03.
Mine did pretty much the same thing, but a bit earlier.
Chris Pettitt
Fixes: 4
Re: pcl-ag03.
Pcl bng-02 is the very best, at least in rural Dorset! Smiley
