packet loss 3rd hop
alanalpha
packet loss 3rd hop
im troubleshooting my connection to eve online (rubberbanding issue) and doing a trace using WinMTR 0.8 i found i get 2 no responses from hop 2 and 7 which im guessing are gateways that dont respond to pings (eve server is hop 8 )
but getting 83% packet loss from hop number 3
195.166.143.137
what is this hop and could this be causing my rubberbanding issue in eve online ?
average ping times look good at around 25ms
2 REPLIES 2
Chris
Legend
Fixes: 169
Re: packet loss 3rd hop
Is the packet loss showing at the end of the trace? If not, then you can disregard it during hops on the trace.
Can you provide the full trace?
Beyhive
Fixes: 43
Hi @alanalpha,
Your connection is absolutely fine after testing it from this line.
If you could please provide the full trace so we can have a look.
 Faris
