over estimated speeds !!!!
- over estimated speeds !!!!
08-05-2013 8:59 PM
1. Best Effort Test: -provides background information.
Download Speed
29.73 Mbps
0 Mbps 38.72 Mbps
Max Achievable Speed
Download speedachieved during the test was - 29.73 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-38.72 Mbps .
Additional Information:
IP Profile for your line is - 38.72 Mbps
Upload Speed
1.79 Mbps
0 Mbps 2 Mbps
Upload speed achieved during the test was - 1.79Mbps
Upstream Rate IP profile on your line is - 2 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Re: over estimated speeds !!!!
08-05-2013 9:05 PM
Podman
08-05-2013 9:10 PM
Are you on Essentials or Unlimited Fibre? The lower cost 'Essentials' product has a maximum download speed of 40Mb/s (Sync) so a maximum download around 38, 'Unlimited' allows the full FTTC maximum speed of 80Mb/s (sync) allowing up to around 76Mb/s throughput - if you're close enough to the cabinet.
Essentials should have an Upstream profile of 10Mb/s, Unlimited has an Upstream profile of 20Mb/s - there was an old version of FTTC with 40Mb/s down and 2Mb/s up and your figures look exactly like that.
It may well be worth a call to customer service to check what profile you've been provisioned on.
08-05-2013 9:20 PM
08-05-2013 9:28 PM
Unlimited is 80/20, Essentials is 40/10 but 40/2 is a legacy profile (at least from Plusnet - may still be in use within the BT systems though).
09-05-2013 11:22 AM
I've taken a look over your account and can see that you've been provisioned on the 40/2 product. I've placed a modify order to move you to the 80/20 product which will complete tomorrow and we'll then hopefully see an improvement.
Let me know how you get on.
09-05-2013 1:46 PM
13-05-2013 9:23 AM
13-05-2013 1:01 PM
Download Speed
36.44 Mbps
0 Mbps 77.44 Mbps
Download speedachieved during the test was - 36.44 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
IP Profile for your line is - 77.44 Mbps
Upload Speed
14.87 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 14.87Mbps
13-05-2013 1:05 PM
13-05-2013 1:06 PM
13-05-2013 4:37 PM
13-05-2013 4:49 PM
14-05-2013 9:21 AM
14-05-2013 9:33 AM
