outside signal
katykitten
outside signal
im having a garden room built around 50 yards from the house, the signal is already pretty poor at the extremeties of the house, how can i either boost the signal or find a way to receive a signal outside?  would plusnet supply another router or is there one i can purchase which will do the job/boost the original router
thanks
Fixes: 62
Re: outside signal
will the garden room have mains electricity - if it does a homeplug would do the job
katykitten
Re: outside signal
Quote from: Oldjim
yes it will have power, can you tell me what a homeplug is please and how to get hold of one
many thanks
Fixes: 62
Re: outside signal
http://www.pcadvisor.co.uk/buying-advice/network-wifi/3370997/homeplug-powerline-networking-adaptors...
I am no expert but I expect that others will be along to give more pertinent advice
Re: outside signal
I used TP Link AV 500 powerline adaptors. You plug the small plug into the electricity supply near to your router & connect it to the router with an ethernet cable & then you will be able to plug the larger adaptor into the electricity supply in your summer house where it will act like a router. You can then use it wirelessly or with an ehternet cable.
They are very easy to set up & connect to but if you do have a problem the telephone customer support is very helpful.
http://www.amazon.co.uk/gp/product/B00DHB2T44/ref=oh_details_o05_s00_i00?ie=UTF8&psc=1
