outside signal
- Re: outside signal
outside signal
25-05-2014 11:26 AM
im having a garden room built around 50 yards from the house, the signal is already pretty poor at the extremeties of the house, how can i either boost the signal or find a way to receive a signal outside? would plusnet supply another router or is there one i can purchase which will do the job/boost the original router
thanks
thanks
Message 1 of 5
(1,073 Views)
4 REPLIES 4
Re: outside signal
25-05-2014 11:31 AM
will the garden room have mains electricity - if it does a homeplug would do the job
Message 2 of 5
(425 Views)
Re: outside signal
26-05-2014 9:28 PM
Quote from: Oldjim will the garden room have mains electricity - if it does a homeplug would do the job
yes it will have power, can you tell me what a homeplug is please and how to get hold of one
many thanks
Message 3 of 5
(425 Views)
Re: outside signal
26-05-2014 9:54 PM
http://www.pcadvisor.co.uk/buying-advice/network-wifi/3370997/homeplug-powerline-networking-adaptors...
I am no expert but I expect that others will be along to give more pertinent advice
Message 4 of 5
(425 Views)
Re: outside signal
27-05-2014 7:58 AM
I used TP Link AV 500 powerline adaptors. You plug the small plug into the electricity supply near to your router & connect it to the router with an ethernet cable & then you will be able to plug the larger adaptor into the electricity supply in your summer house where it will act like a router. You can then use it wirelessly or with an ehternet cable.
They are very easy to set up & connect to but if you do have a problem the telephone customer support is very helpful.
http://www.amazon.co.uk/gp/product/B00DHB2T44/ref=oh_details_o05_s00_i00?ie=UTF8&psc=1
Message 5 of 5
(425 Views)
