outlook saying cannot connect to network whilst online
- outlook saying cannot connect to network whilst on...
23-08-2007 11:08 PM
I have set up my plusnet email account details ok in MS Outlook but when I test them or try sending e-mails I get the error message which says "unable to connect to the internet or network. Use the connections settings for more info" I have checked this and the connect via local lan is ticked. I can get online etc OK but it will not send outgoing e-mail. Would be gratefull for any suggestions. I use a modem router and share a connection with another computer
Message 1 of 3
(1,296 Views)
2 REPLIES 2
Re: outlook saying cannot connect to network whilst online
23-08-2007 11:35 PM
Do you use antivirus and/or firewall? Which products?
What operating system do you use?
Do you get any error messages accompanying Outlook "will not send outgoing e-mail"?
Are you sending from the account mailbox or a personal one? Have you entered the correct POP3 and SMTP server details, the correct mailbox username and password, ticked "Remember password" but *not* ticked "Log on using Secure Password Authentication"?
David
Message 2 of 3
(298 Views)
24-08-2007 6:31 AM
Have you read Outlook Setup Guide?
http://www.plus.net/support/email/setup/outlook.shtml
Message 3 of 3
(298 Views)
