our speed has dropped incredibly recently.
marchend
We used to get speeds of 15-20 mbps at all times and now we are stuck at 4-6.
I have viewed the sticky and (think) I have all the information here, was wondering if there is anything that can be done.. we don't have another router we can test either
is there anything that can be done?
kind off out of my depth here so i'm not sure what all of this means
Plusnet Staff
Plusnet Staff
Re: our speed has dropped incredibly recently.
Thanks for this, your screen shots shows exactly what the problem is.
Right at the bottom, your sync speed and profile speed are miles apart. We now need to find out why....which is what I'm doing now.
 Tony
 Plusnet Support
Plusnet Staff
Plusnet Staff
Did anything unusual happen around the evening of the 23rd, for example loss of service including phone or broadband? This is when your sync dipped to 8128k, hence the bRAS dropped. Sync returned to 21339k yesterday evening. The bRAS profile should follow that, but I'll just check with BTw when it's expected to change. Sometimes we can ask them to make the change instantly. More news soon.
EDIT: I've just checked and this should be sorted now. Please disconnect and reconnect. If you see problems still, please do the BT speed test again and provide me with the new line rate. Thanks.
 Tony
 Plusnet Support
marchend
Thanks a bunch!
Just reset the router and all is fixed! Back up to our normal speed! Smiley
Plusnet Staff
Plusnet Staff
Keep a close eye on any drops in the connection. Your drop in sync for a relatively short period of time caused the problems. Pleased it's sorted now anyway.
 Tony
 Plusnet Support
