optimum MTU value using 3rd party router ?
- optimum MTU value using 3rd party router ?
06-03-2014 7:53 AM
Hi all
Im using a Netgear R7000 router with my openreach fibre modem and wanted to know if there is an optimum setting for MTU ?
Default is 1492 .
Have read if using 3rd party router with openreach modem then should be set to 1458 (BT advised someone)
Also heard 1400 is best setting .
Any help most appreciated
Karl
Default is 1492 .
Karl
Message 1 of 7
(2,706 Views)
6 REPLIES 6
Re: optimum MTU value using 3rd party router ?
06-03-2014 10:11 AM
Message 2 of 7
(1,355 Views)
06-03-2014 11:06 AM
I dont know how 1400 has ever been determined to be a optimal value, it seems one of those internet myths that just wont stop spreading.
Without RFC 4638 the optimal value is 1492, with RFC 4638 its 1500.
Message 3 of 7
(1,355 Views)
06-03-2014 12:14 PM
Thanks for the replies.
What is RFC ?
Probably give the 1458 setting a go… see if makes any difference… can soon change back lol
Karl
What is RFC ?
Karl
Message 4 of 7
(1,355 Views)
06-03-2014 12:42 PM
The standard MTU for a PPPOE connection as used on BT Wholesale fibre is 1492. So why not use that!
Ethernet Frame length is 1500 bytes with an 8 byte overhead for PPPOE. I believe RFC4638 which probably isn't supported by your router allows an increased frame length.
As for 1458, wasn't that some strange anomaly on AOL dial up, certainly not relevant now. 1400 - I don't think so!
Message 5 of 7
(1,355 Views)
06-03-2014 12:54 PM
Ok , will try 1458 out of interest… if no different then will stick with 1492… default setting .
Cheers
Cheers
Message 6 of 7
(1,355 Views)
09-03-2014 10:25 AM
I'm sure I've seen previous posts from Plusnet staff in response to a similar question recommending an MTU of 1500.
Message 7 of 7
(1,355 Views)
