one month now
snipperuk
one month now
well its one month since my connection has halved
previous stats  were .... sycn speed 2400 , line ip 2000 and snr 6db
current stats are  ...... sync speed 1024, line ip  750 and snr 12db
last week i had a BT engineer fit a new master socket  due to a dodgey one and he tested my line error free with a sync rate of 960kbps  Roll eyes
but he said some cables are been changed near the exchange and should be done by the weekend ........
any chance of PN admin checking if they have finished and if so why my line is still suffering poor speeds as all my equipment is fine and line confirmed
having a slow speed
many thanks  Cry
Fixes: 9
Re: one month now
Keep an eye on your connection for the next couple of days - it it stays continually connected you could request a SNR reset which will put the snr back to 6 and the sync speed back up to where it used to be.
It should do it automatically, but it takes a painfully long time!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
snipperuk
Re: one month now
after a phone call today from PN i was told that 960kbps line speed and an ip 750 was acceptable for my length of line
even though i have been with PN for 5yrs with an average line IP of 1500 and the past 8months an ip of 2000  Roll eyes
if it doesnt get sorted im going down the mifi route or another isp
Fixes: 9
Re: one month now
What's your attenuation?
snipperuk
Re: one month now
63.5  with a noise margin of 6db ( or it allways was ...12db now)
my uncle nextdoor has an attenuation of 62  but he is with talk talk and syncs at 2200/2300kbps
jojopillo
Re: one month now
Hi snipperuk,
as jelv said, If I snr reset we'd probably get the sync a lot higher. I would be happy to try that if the line has been fixed.
Jojo Smiley
Fixes: 9
Re: one month now
http://www.kitz.co.uk/adsl/max_speed_calc.php only takes whole numbers, for 64 it predicts a sync of 1792 with a 1500 IP Profile.
Quote from: snipperuk
I am getting seriously unimpressed with CSC.
Quote from: Joanne
Thank God for Digital Care!
snipperuk
Re: one month now
jojo to the rescue  Cheesy
yes please jojo ............ worth a try
snipper  Kiss
jojopillo
Re: one month now
Hi snipperuk,
I'll give it a go but if it goes back up again then there's nothing I'd be able to do about that. Also remember that the line will go into the 10 day training period.
Jojo Smiley
jojopillo
Re: one month now
Hi snipperuk,
your profile is now 1500 and SNR 6dB. It's showing a lot of errors though so I'd imagine that may creep up a bit.
Jojo Smiley
snipperuk
Re: one month now
thanks jojo
just checked and the noise margin is 6db so half what it was but my sync is the same  Undecided
Connection Speed 1056 kbps 448 kbps
Line Attenuation        61 db 15.5 db
Noise Margin              4 db 19 db
any ideas why the sync speed hasn't moved ?
thanks snipper
jojopillo
Re: one month now
Hi snipper,
when I tested it just after the reset it was1856k but there were a lot of errors, so not sure why it's dropped again. I've just tested and got an SNR of 8dB, which will account for most of that. To be honest, bearing in mind you are in the test socket and have tried different filters, have you tried a different router?
Jojo Smiley
snipperuk
Re: one month now
hi jojo
ive tried 2 netgear routers .......... i did get a text from PN today saying the cable laying might still be on going
but the BT engineers report is on my ticket now
snipper
jojopillo
Re: one month now
Hi snipper,
I'll see if I can find out more about that cable laying. It does sound suspiciously like it could be something like that causing it.
Jojo Smiley
