now download speeds using u torrent,help
brettking24
Hi i got a email to sya ive gone over my download usage but i didnt think plusnet would cut of my downloads speeds overnight which is of peak times.i thought of peak was unlimited.
any ideaS?
10 REPLIES 10
brettking24
Re: now download speeds using u torrent,help
yeh thats bad as i always thought offpeak was unlimited usage!
orbrey
Checking your usage and connections you're doing everything within peak time - you're on BBYW option 4 and the peak time runs from 8am to midnight. If you do your downloading overnight you'll be able to avoid this in future.
brettking24
so it matters which way round i do it,so can i download as much as i like overnight and that wont affect my 40gb downloading usage during peak times?
brettking24
when does my 40gb dl usage begin again?
orbrey
Usage is counted from 8am to midnight. Usage from midnight to 8am is free.
EDIT: Apologies, I misunderstood the question - please see Colin's reply below. Sorry about that.
Colin
Your 40GB usage runs for the duration of your billing month - so if you get billed on the 17th, your 40GB is for use between the 17th of this month, and the 16th of the next, when it will reset.
brettking24
ok my billing date is the 18th so will it be reset today?
James
Hi Brett,
This should happen in the early hours of tomorrow afternoon.
Regarding the PUGIT query, usage is restricted 24/7 once the limit has been reached by design.  This is down to the economics of the product, rather than it actually being done in error.
brettking24
ok thanks,could you please notify me on this this forum when its been reset
brett
jelv
Fixes: 10
If you go to My Questions you will see a new closed ticket (you will need to select closed questions from the dropdown) added to your account when the usage is reset (I suggest you look at last months to see what it looks like).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
