noise margin
hitachi
noise margin
Hi
A couple of weeks ago my exchange was upgraded,since then my noise margin has been between 7.5 and 8,am I right in assuming this should be more like 6.
If this is the case is this something plusnet can change.
Protocol: G.DMT2+ Annex A
Downstream Rate: 18769 kbps
Upstream Rate: 1176 kbps
Channel: Fast
Current Noise Margin: 7.9 dB (Downstream) 6.1 dB (Upstream)
Current Attenuation: 4.2 dB (Downstream) 3.8 dB (Upstream)
Current Output Power: 11.1 dBm (Downstream) 12.3 dBm (Upstream)
I have had 636 errored seconds and 853 uncorrected blocks in the last ten days,so the connection is fairly stable.
Cheers.
Fixes: 23
Re: noise margin
Quote from: hitachi
Not if you live next door to the telephone exchange as you appear to, judging from the amount of attenuation.
hitachi
Re: noise margin
Opposite side of the road. Smiley
I could understand that if I was getting full speed synch,but I am not.
Fixes: 51
Re: noise margin
Are you really wanting the squeeze the last bit of downstream performance from your connection? Assuming your target noise margin is 6dB (as seems likely) restarting the router when the current value is around 8dB might give you a slightly higher sync speed.
However, left to its own devices the DLM might decide to try a 3dB target noise margin, perhaps after 14 days, which might achieve a little more. Basically it's your call - though my inclination would be to give the DLM a chance.
David
David
Fixes: 23
Re: noise margin
Quote from: hitachi
That's really the issue, isn't it.  What you would expect with such a low attenuation is the maximum sync speed and quite a high noise margin.  Have you tried the standard plug-the-router-into-the-test-socket procedure for debugging speed issues?
hitachi
Re: noise margin
Unfortunately I have no master socket,the line in goes to a small junction box then onwards to a standard socket.
@ spraxyt, Not that bothered really,just curious.
hitachi
Re: noise margin
I found the problem,the firmware on my ex BT 2700 hgv does not go below 8 dB,so a change is in order.
