no dns connectivity
ox06
no dns connectivity
Evening all,
Last couple of weeks our internet connection has ground to a halt, working very slowly and at weekends not at all. Impossible to stream. Had a decent connection for the last three years.
the thomson router is TG585 v8, software release 8.2.7.7
My internet connectivity check flags this:
Connectivity to Gateway (195.166.130.34)  ✔
Connectivity to DNS Server 1 (212.159.6.9)  ✖
Connectivity to DNS Server 2 (212.159.6.10)  ✖
Estimated line speed 5mb
BT Wholesale test
Download Speed (Mbps): 0.13
Upload Speed (Mbps): 0.00
Ping Latency (ms): 0.00
Uptime: 0 days, 7:28:04
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 820 / 704
Bandwidth (Up/Down) [kbps/kbps]: 448 / 160
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 27.94
Output Power (Up/Down) [dBm]: 12.0 / 14.0
Line Attenuation (Up/Down) [dB]: 23.5 / 37.5
SN Margin (Up/Down) [dB]: 16.0 / 29.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Signal (Local/Remote): 1,966,054 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2,031,589 / 0
FEC Errors (Up/Down): 0 / 4,538
CRC Errors (Up/Down): 0 / 6
HEC Errors (Up/Down): 0 / NA
Tried different filters - any suggestions please!?
Ox
6 REPLIES 6
flaminmoses
Re: no dns connectivity
i stopped using plusnets dns servers ages ago.
there is a bit of software that lets you find the best one for you....cant remember the name.
Oldjim
Resting Legend
Fixes: 63
Forget about the DNS server connectivity it is an incorrect result from the router
Your problem is that your line is apparently banded http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml#bandedProfiles with an enormous number of errors
The first thing is do you have a master socket with a removable lower faceplate
Second are you absolutely sure that everything attached to the phone system including Sky Box, Monitored Alarm, etc is filtered
beetnik
Quote from: flaminmoses
DNSBench.exe from grc.com
and this is one reason why you might wish to change (2 minutes ago - Plusnet's DNS servers sloooooooooow):
adamwalker
Fixes: 221
FYI I've performed some diagnostics and the line isn't banded.
 Adam Walker
Chris
Legend
Fixes: 169
Just to add to Adam's post, he's still running some checks. It's a 20CN line so it's not banded.
adamwalker
Fixes: 221
I've submitted an SNR reset which should hopefully resolve this.
However @ox06 we're seeing a few disconnections which might be causing some issues. Is this something you're aware of?
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13667929381692.png"/>
 Adam Walker
