no dns connectivity
- Re: no dns connectivity
no dns connectivity
22-04-2013 8:53 PM
Evening all,
Last couple of weeks our internet connection has ground to a halt, working very slowly and at weekends not at all. Impossible to stream. Had a decent connection for the last three years.
the thomson router is TG585 v8, software release 8.2.7.7
My internet connectivity check flags this:
Connectivity to Gateway (195.166.130.34) ✔
Connectivity to DNS Server 1 (212.159.6.9) ✖
Connectivity to DNS Server 2 (212.159.6.10) ✖
Estimated line speed 5mb
BT Wholesale test
Download Speed (Mbps): 0.13
Upload Speed (Mbps): 0.00
Ping Latency (ms): 0.00
Uptime: 0 days, 7:28:04
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 820 / 704
Bandwidth (Up/Down) [kbps/kbps]: 448 / 160
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 27.94
Output Power (Up/Down) [dBm]: 12.0 / 14.0
Line Attenuation (Up/Down) [dB]: 23.5 / 37.5
SN Margin (Up/Down) [dB]: 16.0 / 29.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Signal (Local/Remote): 1,966,054 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2,031,589 / 0
FEC Errors (Up/Down): 0 / 4,538
CRC Errors (Up/Down): 0 / 6
HEC Errors (Up/Down): 0 / NA
Tried different filters - any suggestions please!?
Ox
BT Wholesale test
Ox
Message 1 of 7
(1,132 Views)
6 REPLIES 6
22-04-2013 8:55 PM
i stopped using plusnets dns servers ages ago.
there is a bit of software that lets you find the best one for you....cant remember the name.
Message 2 of 7
(532 Views)
22-04-2013 9:05 PM
Forget about the DNS server connectivity it is an incorrect result from the router
Your problem is that your line is apparently banded http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml#bandedProfiles with an enormous number of errors
The first thing is do you have a master socket with a removable lower faceplate
Second are you absolutely sure that everything attached to the phone system including Sky Box, Monitored Alarm, etc is filtered
Message 3 of 7
(532 Views)
23-04-2013 7:40 PM
Quote from: flaminmoses i stopped using plusnets dns servers ages ago.
DNSBench.exe from grc.com
and this is one reason why you might wish to change (2 minutes ago - Plusnet's DNS servers sloooooooooow):
Message 4 of 7
(532 Views)
24-04-2013 9:34 AM
Message 5 of 7
(532 Views)
24-04-2013 9:40 AM
Just to add to Adam's post, he's still running some checks. It's a 20CN line so it's not banded.
Message 6 of 7
(532 Views)
24-04-2013 9:42 AM
I've submitted an SNR reset which should hopefully resolve this.
However @ox06 we're seeing a few disconnections which might be causing some issues. Is this something you're aware of?
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13667929381692.png"/>
Message 7 of 7
(532 Views)
