news group / usenet access
SteveA
Re: news group / usenet access
worth raising a ticket anyone?
Or do I just watch Master and Commander instead ?
Fixes: 1,483
Worth flagging up, might be fixed for when Master and Commander finishes..
Roswellgrey
Well, it was Ok at 1900 Sad
But,  as per others , it pretty sick now ....
SteveA
Ticket raised
James
Leave it with me, I'm just giving networks a call.
Was definitely working earlier.
HairyMcbiker
All Star
Fixes: 21
Its not only affecting plusnets server, my astraweb & usenetnews are runing VERYYYYYYYYYYYYYYYYYYY SLLLLLLLLLOOOOOOOOOOOOOOOWWWWWWWWWWWLLLLLLLLLLLLYYYYYYYYYYY.
Maxing at 5KBs/s instead of the 128/256Kb it should be getting  Cry
MauriceC
Resting Legend
Fixes: 17
I'm not getting any authentication errors and the newsgroup Headers come down quite quickly, but the message body download is  **CENSORED** slow.   Usenet is for all practical purposes unusable at the mo.
M
James
Thansk for the feedback.
I've got someone from the CSC trying from one of our test lines to see if they can reproduce the problems you guys are seeing.
James
Just to update.
We've noticed an ellacoya change that needs making for access to our own servers.
I've a P1 raised which is being worked on atm.
James
We believe that access to our text based newsgroups should now be working fine and in a timely manner.
Apologies for the problems throughout the day.
MauriceC
Resting Legend
Fixes: 17
UPDATE:  Had a short intermission about 10 minutes ago with no access to the Mail Server.   Then as I was raising a fault report  access was restored - and with it a much improved performance on Usenet message body downloads.   Not perfect yet, but definitely much better Cheesy
dave
Fixes: 4
Change has been made on the Ellacoya DB, you might need to close your usenet client and give it 15 minutes for the change to completely take effect but my testing here shows it being picked up correctly now.
Dave Tomlinson
Plusnet Technology
tobykim
Was on ag03 and it was absolutely crawling at the time of this post, did a soft router rebbot and got onto ag02 and running fine so something must still be wrong
SteveA
Connect times are pretty lousy, but once its connected it seems to be working OK.
I've updated the ticket just in case.
hneil
When I try to access newsnet, I am asked for username and password (cannot remember ever having this before). I have tried my usual Plusnet username and password but this is not recognised. Is this part of the same problem, please, or is there a different username and password which I should know?
