new router, very low speeds :(
- new router, very low speeds :(
- « Previous
- Next »
Re: new router, very low speeds :(
26-11-2007 10:22 AM
I do suspect that this may boil down to exchange contention, but we'll find out in due course.
26-11-2007 10:23 AM
26-11-2007 2:48 PM
trying to get a couple more shorter ethernet cables as well.
just wondering can plusnet reset an adsl profile?
would that even make any difference?
26-11-2007 2:55 PM
Hope that helps,
26-11-2007 3:06 PM
it does seem as though something is throttling the connection
I know I was on level 1 management, just wondering can you double check or reset the traffic filter system?
as you can see I am clutching at straws here and do not know if you can do that or not.
right have got 3 new shorter ethernet cables, a new broadband cable and a new router to try.
26-11-2007 4:42 PM
I've just checked with someone in the know, and you're certainly on the right service offer for your product.
26-11-2007 5:08 PM
cheers
26-11-2007 6:37 PM
sorry for wasting all your time
did not have PPPoA but PPPoE
i feel like a right fool now
speeds :
26-11-2007 18:30:21 5350.8
26-11-2007 09:08:30 28610
25-11-2007 18:40:42 941.9
although am getting :
The login name entered on this tool doesnt match that discovered by querying the network for your domain name. Please check your telephone number (or user name) and try again. If problem persists please contact your CP.
from the bt speed test site
27-11-2007 11:37 AM
I think everyones been the idiot in the corner at some stage, I know I have
The BT Speedtest seems to generate random errors when it's busy. I'd persevere with it and see if it eventually lets you in.
27-11-2007 11:55 AM
I wish I had that speed at home
- « Previous
- Next »
