new router, very low speeds :(
- new router, very low speeds :(
Re: new router, very low speeds :(
22-11-2007 10:36 AM
Glad you're latency is good though
22-11-2007 10:41 AM
i think this case is one of those strange dsl cases that come up every now and then.
or windows has gone ultra wonky - this is the most likely scenario
24-11-2007 9:29 PM
using the zyxel router and windows vista home premium
router is : P-660H-D1
it is syncing on the router 8128/448
throughput is 6500
noise margin upstream: 25 db
output power downstream: 19 db
attenuation upstream: 13 db
IP Address: 192.168.1.1
IP Subnet Mask: 255.255.255.0
from plus.net speed test :
24-11-2007 21:10:47 249.3
23-11-2007 21:59:05 1104.5
23-11-2007 21:58:14 934.8
23-11-2007 21:52:50 875
23-11-2007 21:50:27 818.2
23-11-2007 21:46:30 993.6
23-11-2007 21:45:49 1420.3
23-11-2007 21:45:25 1033
23-11-2007 21:45:00 656.8
21-11-2007 22:37:28 1014.1
I am pulling my hair out at the moment.
exchange is green :
Virtual paths: Green
There are currently no known capacity problems on your exchange
Your High-speed Broadband Service
Your current broadband speed is 6500 Kbps
any ideas?
24-11-2007 9:58 PM
not sure if i can use my binatone usb modem with windows vista?
so that might be a problem.
thanks
zippy666
25-11-2007 10:10 AM
well the speedtest says it is busy at present.
but downloads are looking better - getting upto 400Kb/s download speeds now.
last night it was awful.
maybe because i updated mobo drivers this morning. (brand new mobo, with brand new nic, fitted that yesterday).
will try and get some proper speed testing done.
will update asap
25-11-2007 10:54 AM
25-11-2007 10:56 AM
from : http://www.mybroadbandspeed.co.uk/?hasFlash=true&
Today 10:55 1146 kbps (143kB/s) 382 kbps (47.8kB/s) Share
Today 10:54 325 kbps (40.6kB/s) 382 kbps (47.8kB/s) Share
Yesterday 21:35 301 kbps (37.6kB/s) 382 kbps (47.8kB/s)
will be back with more findings
cheers
25-11-2007 7:01 PM
as you can see all over the place :
Today 18:38 1415 kbps (177kB/s) 378 kbps (47.3kB/s) Share
Today 18:37 1190 kbps (149kB/s) 378 kbps (47.3kB/s) Share
Today 18:37 1281 kbps (160kB/s) 378 kbps (47.3kB/s) Share
Today 18:36 1382 kbps (173kB/s) 378 kbps (47.3kB/s) Share
Today 18:36 1420 kbps (178kB/s) 378 kbps (47.3kB/s) Share
Today 18:24 290 kbps (36.3kB/s) 378 kbps (47.3kB/s)
25-11-2007 7:03 PM
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 6500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1130 kbps
it is as though something is sucking 80% of my bandwidth somewhere.
has anyone got any further ideas?
25-11-2007 7:37 PM
I have turned off the zyxel router firewall
I have turned off windows defender
I have turned off windows firewall
and still slow connections.
downloading a 100Mb test file from an ftp server I was getting 25Kb/s.
downloaded ea stores download manager at 75Kb/s
where is the bandwidth?
I need some serious help
25-11-2007 10:23 PM
Actual IP throughput achieved during the test was - 1332 kbps
26-11-2007 8:55 AM
as it pc needs to be turned on, will need to do this tonight.
thanks
26-11-2007 9:43 AM
You would only need to leave your router turned on. We just need to be able to see your connection being online so that we can run various tests.
26-11-2007 9:50 AM
will hopefully be able to do this tonight.
around 6pm to 7pm
thanks
26-11-2007 10:19 AM
I think you need to make sure your router is configured to accept ping from the net for this purpose.
