new router slower speeds?
- Re: new router slower speeds?
19-09-2011 11:14 AM
I had a trusted TG585 v7 that was connecting at over 4mbs with a 3.5mb profile (great for my line). But when I tried to do some port forwarrding for games it kept rebooting so I decided to invest in a new one. A Belkin wireless N150. On plugging it in it synced at about 3mb, then I needed to reboot it and it dropped to 2mb, overnight it rebooted again and Im now at a sync speed of 1.6mb.
Have I got an iffy new router? I would hope that a new router should at least sync at the same sort of speed I was enjoying before?
Any ideas?
Any ideas?
Message 1 of 7
(1,192 Views)
6 REPLIES 6
19-09-2011 11:46 AM
It should (more or less) - please post the full router stats
Message 2 of 7
(666 Views)
19-09-2011 6:36 PM
Hi AJJ,
I changed my router from a v7 to a netgear and also found a drop in connection speed. It could be to do with the time of day/SNR. Your stats will help.
Jojo
Jojo
Message 3 of 7
(666 Views)
19-09-2011 7:43 PM
what do you make of these? (sorry about the formatting)
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps)
1720Kb 447Kb
Noise Margin
3 16
Output power(dBm)
126 168
Attenuation(dB)
65 33
Status SHOWTIME
Downstream Upstream
Data rate(Kbps)
1720Kb 447Kb
Noise Margin
3 16
Output power(dBm)
126 168
Attenuation(dB)
65 33
Message 4 of 7
(666 Views)
19-09-2011 7:57 PM
Also,
got this from the security log:
09/19/2011 16:43:24 If(ATM1) PPP connection ok !
09/19/2011 16:43:23 ATM1 get IP:31.185.42.137
09/19/2011 16:43:22 ATM1 start PPP
09/19/2011 16:43:21 ADSL Media Up !
09/19/2011 16:42:53 ATM1 stop PPP
09/19/2011 16:42:53 ADSL Media Down !
09/19/2011 14:00:52 DDNS> Updated IP 31.185.42.137 Successfully.
09/19/2011 14:00:52 If(ATM1) PPP connection ok !
09/19/2011 14:00:50 ATM1 get IP:31.185.42.137
09/19/2011 14:00:45 ATM1 start PPP
09/19/2011 14:00:45 If(ATM1) PPP fail : Timeout in CHAP negotiation
09/19/2011 14:00:11 ATM1 start PPP
09/19/2011 14:00:11 If(ATM1) PPP fail : Peer terminate
09/19/2011 14:00:09 ATM1 start PPP
09/19/2011 11:47:13 NTP Date/Time updated.
but no one was in using the broadband. Have I missed something in the basic configuration for this router?
Message 5 of 7
(666 Views)
19-09-2011 9:32 PM
When I tried the Netgear DG834G v5 my sync speed dropped 500kbps when compared to the DG834G v4 due to the different chipset and it is quite likely the Belkin has the same problem as it may not have a Broadcom chipset like my DG834G v4 and your TG585 which are good on long lines
However that isn't your problem
Something has wacked up the reported attenuation which, as you haven't moved house, is probably either a dodgy router or cable
Message 6 of 7
(666 Views)
20-09-2011 8:48 AM
well OldJim,
you are indeed correct. I removed all of my network cables and then hunted through some old routers to find a new ADSL cable (whats the difference between the 4 core ones and 2 cores? - dont say 2 wires please!)
and plugged it back into the ADSL filtered face plate this morning and it came up a 4mb! Not happy with the fact that the new router comes with such a poor cable?
now just to plug the network ones back in one at a time and see if that has any affect!
Message 7 of 7
(666 Views)
