new premium service stuck at fixed 2272 / 288
spark3
I've just got a new Plusnet Premium service and everything's gone smoothly so far except that I seem to be stuck at a fixed 2MB rate. It always syncs at exactly 2272 down, 288 up even though the PN profile is 7150.
Can anyone tell me if this is right? It hasn't been 10 days yet, but this doesn't seem right.
Thanks.
Here are the BT test results:
Download speedachieved during the test was - 1681 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2272 Kbps(DOWN-STREAM), 288 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
Here are the router stats:
Link Information
Uptime: 0 days, 2:42:03
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 288 / 2,272
Output Power (Up/Down) [dBm]: 11.0 / 11.0
Line Attenuation (Up/Down) [dB]: 5.0 / 7.0
SN Margin (Up/Down) [dB]: 27.0 / 29.5
Vendor ID (Local/Remote): TMMB / P
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Re: new premium service stuck at fixed 2272 / 288
This seems to happen quite often.  Check out this thread:
http://community.plus.net/forum/index.php/topic,79576.448.html
Mand
@coastergrotto, that's not a stuck profile, the sync speed is 2272, so a 2000 profile is correct.
@spark3, I'm taking a look at your account now.
Mand
You're definitely on Max, and there's nothing strange showing so far.
We're going to need to see how it plays out over the 10 days (we can't raise a fault 'til after then anyway).
Fixes: 21
Mand, that's ridiculous, if those stats are anywhere near right, he's living in the exchange and should be syncing at 8M, he shouldn't have to wait 10 days.
Mand
I know, but you physically cannot raise a fault in the first 10 days (the system rejects it outright). Sad
Fixes: 21
I realise that, but I'd be on the phone to BTw if it were me and asking for it to be escalated if no-one were prepared to look at it.
Mand
I'm usually well up for an arguement with BTw Cheesy, but IME arguing in this scenario has proved very much fruitless in the past.
Fixes: 21
Go on Mand get your cricket bat out Wink You can call on us if you need reinforcements  Kiss
Mand
OK OK Cheesy
I'll see what I can do tomorrow, don't get your hopes up though.
Fixes: 10
Is there an option for MaxDSL to be locked at the old 2MB fixed rate connection speeds? Because that's what it looks like to me.
The 10 days is fair enough for iffy lines not performing as they might, or for the IP Profile not corresponding to the sync speed, but this looks like something very different.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Mand
@spark3, try a reconnect and things should be much better. Smiley
spark3
Thanks for the help everyone, and thanks for sorting this out so quickly Mand -  its up and running properly now.  Smiley
Download speedachieved during the test was - 5790 Kbps
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Mand
Glad to hear it. You may still see a little fluctuation in speed given that you're in the first 10 days.
