new order without router?
scoobydoo1
hi ive just ordered plusnet unlimited broadband, I decided not to get a router with them,
my question is do plusnet send me the log in details by post (for the router) like password to connect to wifi when at home etc
or do I need to contact plusnet to request these?
or are they in my account already somewhere?
Fixes: 162
Re: new order without router?
We'll provide the details of your broadband connection details, however if you're not taking our router then connecting to the wifi after that would be a case of following the router instructions.
 Chris Parr
 Plusnet Staff
Fixes: 10
What router are you planning to use?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
scoobydoo1
thanks for quick reply yes I have (about a year old) router from plusnet, you say you will provide the details, how is this done , by email? or by post?
Fixes: 10
The wifi connection details and the password to access the router will not change from when you used it before (they are on the bottom of the router).
The connection details will be username@plusdsl.net using the password you use to log in to the members centre.
Fixes: 162
They can also be seen here: http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
 Chris Parr
 Plusnet Staff
