new order without router?
- Re: new order without router?
14-10-2015 11:02 AM
hi ive just ordered plusnet unlimited broadband, I decided not to get a router with them,
my question is do plusnet send me the log in details by post (for the router) like password to connect to wifi when at home etc
or do I need to contact plusnet to request these?
or are they in my account already somewhere?
Message 1 of 6
(776 Views)
5 REPLIES 5
14-10-2015 11:04 AM
We'll provide the details of your broadband connection details, however if you're not taking our router then connecting to the wifi after that would be a case of following the router instructions.
Message 2 of 6
(499 Views)
14-10-2015 11:10 AM
What router are you planning to use?
Message 3 of 6
(499 Views)
14-10-2015 11:12 AM
thanks for quick reply yes I have (about a year old) router from plusnet, you say you will provide the details, how is this done , by email? or by post?
Message 4 of 6
(499 Views)
14-10-2015 11:20 AM
The wifi connection details and the password to access the router will not change from when you used it before (they are on the bottom of the router).
The connection details will be username@plusdsl.net using the password you use to log in to the members centre.
Message 5 of 6
(499 Views)
14-10-2015 12:01 PM
They can also be seen here: http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Message 6 of 6
(500 Views)
