new on fibre unlimited - correct profile?
- Re: new on fibre unlimited - correct profile?
12-02-2013 10:38 PM
Hi
Just gone onto fibre unlimited , Openreach guy installed on the 11th feb..but i see quite a few ppl put on the wrong profile...
could one of the plusnet team check that i am the right profile as i am working away from home, so unable to check for the next few days
I should be getting max speed as i previously used to get 20MBit on ADSL 2, so looking forward to max speed as i am less than 100m from the cab
also am i good to go now to change to a fixed IP ? as i havent seen anything from Plusnet to say my line is officially up and running and the install is complete.
cheers and thanks
cheers and thanks
Message 1 of 4
(733 Views)
3 REPLIES 3
13-02-2013 11:16 AM
I've checked your account and the fibre order and you're definitely on the right profile.
Re a static IP, yes you're absolutely fine to go ahead with that. FYI in case you're not aware its under add-ons on our website.
Message 2 of 4
(412 Views)
13-02-2013 9:42 PM
Adam
many thanks for your helpful assistance and checking that for me
Message 3 of 4
(412 Views)
14-02-2013 11:35 AM
Message 4 of 4
(412 Views)
