new master socket, but which?
- new master socket, but which?
28-06-2010 6:03 PM
so looking on maplins i can only see the standard nte5, as i will be putin my hand in my pocket am looking for the nice filtered/ iplatey type socket. ie the one that filters as much interference as humanly possible
point me to the buy button please ?
an shhhh don't tell openreach
this might explain why the fone sounds so quiet, but i thought this was just from being on the end of 63db + atten as this is the longest line i've ever had to use
Re: new master socket, but which?
28-06-2010 7:36 PM
http://www.clarity.it/xcart/home.php?cat=262
Apart from the NTE5, they have a range of DSL faceplates etc.
Probably not the cheapest, but they are a decent operation with quality parts. Been trading for years.
Cheers
MJ
28-06-2010 7:49 PM
I had a name in my head but couldn't get it out, never had to replace a nte5 yet so the name hadn't stuck in my grey matter.
cheers mjservicing
28-06-2010 8:28 PM
i know the pcb lifts easily out of this current nte5 as i all ready done that to check the soldering joints wasn't lose and causing the issue
reading the info on the site there saying there the same and manufactured in the same factory that openreach use but just not with the openreach logo but can any one confirm this?
28-06-2010 9:43 PM
I will update this thread tomorrow when I have found it.
29-06-2010 8:21 AM
29-06-2010 11:26 AM
It is a BT NTE5 with the BT and Pan Piper Logo on it.
29-06-2010 11:40 AM
29-06-2010 11:58 AM
Another advantage of going with Openreach is that you should get the latest technology including iPlate (or equivalent). I don't think you'll find this in a socket with the piper logo.
29-06-2010 12:11 PM
plain and simple i just think its easier to self install than wait about for a vist from openreach and they do the normal trick of not showing up, esp as this address am at is a funny address and no one can find it apart from the regular post man
at the moment i just want a none faulty master to see me right for a bit, luckly the router that PO send you out has default NM offset to keep your snr/nm at 6db so even with this faulty master on a 63db attention line my sync speed hasn't been effected, the router they use is a zyxel
richard, i knew that all ready but still thanks for the advice allways wellcome
29-06-2010 12:39 PM
Have fun....
R
29-06-2010 7:10 PM
Quote from: Asbo ... this address am at is a funny address and no one can find it apart from the regular post man
Arghhhh! It's my job to go and visit people in their homes and they're often their own worst enemies with no house number/name visible from the road. If you want to be found, make it easy for whoever is doing the looking! Put up some signs if necessary.
29-06-2010 10:46 PM
drew a map of the streets and hope that makes it clear why when drivers try to find us they head across the road which is the right place really as this house should be an address of something close and not something drive, took the gas company 2 months to find there way here to change the meter, and yet 2 times they said we wasn't in and left a card (no they didn't )
30-06-2010 12:31 PM
Quote from: ReedRichards I won't tell BT Openreach but the master socket belongs to them and if it has become faulty they should replace it, free of charge AFAIK. There is only a charge (and it's whopping big charge) if it turns out that the problem lies with your equipment, i.e. anything on the house side of the master socket.
You would think that, but I was told I would have to pay for a replacement NTE when it was faulty
06-07-2010 9:38 PM
