new contract only 3 days old - can I cancel without cost?
jd6
New contract only 3 days ago - then found better elsewhere.  I thought I could cancel within 14 days but when I tried to "switch" to another received a text from Plusnet saying as I was in contract Id be charged (lots!)...
Is this right?Huh
3 REPLIES 3
Fixes: 480
Re: new contract only 3 days old - can I cancel without cost?
The 14 day 'cooling off' period is from when you placed the order not when the service started.
See section 9 in the Plusnet standard terms here https://www.plus.net/help/legal/terms/
If you're still within that 14 days from order, then it could just be a rather 'over zealous' automated system sending the text.
Tina11192
Fixes: 13
Hi @jd6 I tried calling you noting only the option to leave a voicemail, I hope you are well.
What @MisterW said is correct, however, if the contract is a renewal contract you may be still in a position to cancel without penalties, provided that this was stipulated within the last 14 days.
I have also emailed you from the account with more detailed response for your circumstance, please follow this link at your earliest convenience: https://www.plus.net/wizard/?p=view_question&id=247808178
Please let me know if there's anything else we may look into for you
Cri Ignatti
jd6
Hi to both who responded. Thanks that helps reassure me - think it was an over zealous automated thing... ordered on 1st may and it was a renewal, activated on 7th. Today is 9th so well within 14 days of the order on the 1st.
I'll go ahead and switch with confidence I won't be charged.
Thanks again
JD
