netgear dg834g v4 firmware advice needed
- netgear dg834g v4 firmware advice needed
21-10-2008 4:57 PM
Any one using the 5.01.09 firmware and is it performing o.k?
Re: netgear dg834g v4 firmware advice needed
21-10-2008 5:06 PM
there is another report on TBB where an increase in synch speed was seen.
http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=dslrouter&Number=3480462
22-10-2008 4:26 PM
have ago at upgrading today. my main reason for posting this was to make sure no one was geting any bad bugs with the 5.01.09 firmware.
22-10-2008 5:06 PM
The DG834 doesn't have some of the bells and whistles that more expensive routers have, eg QoS for VOIP would have been nice, but it looks like OpenWRT support is coming along nicely.
23-10-2008 1:02 AM
mine 52db atten 12 snr set by self with dmt gives me a sync 2720 with profile of 2000.
IF i let my router sync normal it goes with the 9 db default snr on my line and pushes my sync upto about 3400 ish sync and if i set with dmt down to 6 db push it to around 4000 ish sync. but at the 9db and 6db it will hold it for a few days then get a re sync event.
I game so have interleaving off and not sure if the dslam sees to many errors on my line after few days and resyncs me thinking its doing my line good or is a interferce resync not sure as i never left router stats lite runing that long to catch it in the act.
but even with interleaving on and a 6db target best i ever got was a 3500 profile for a wee while before i got a resync and it would knock down to 3000 or 2500 profile
Any way must not moan about it as i never get any lag on my xbox with my 2mb profile and no random resyncs with a low sync speed.
opps the reason i came here and nearly forgot to say after reading MrC at 55db with 4000kbps that i upgraded to 5.01.09 tonight all's well but no increase in sync speed for me
23-10-2008 10:19 AM
Noise Margin: 11.6 dB (drops to about 7.5 overnight)
Connection Rate: 3584 Kbps
Line Attenuation: 52.0 dB
Power: 19.1 dBm
I can't explain the difference between my results and yours
This is what DMT shows - is yours much different
24-10-2008 1:12 AM
But having what to me seems near same line stats seems strange mine syncs lower. just had quick look at the 2 and noticed the power is slighty diffrent and your using alot more tones wonder why my tone range is so limited.
Glad you posted that dmt now.
24-10-2008 9:05 AM
PS, for a "different" DMT graph please see attached!
24-10-2008 2:52 PM
nope only the master socket in this house no extensions. router nxt to the master socket.
There is a power socket pretty close to the master socket thoe surrpose this could cause the intrefence but no chance im re wiring the the power socket some where else and cant move the master socket as bt wag there finger at that sort of stuff.
24-10-2008 4:26 PM
All that i have done is remove the face plate from the master socket and plug into the test socket. Should not make any diffrence as i have no extensions. So dont know why i am seeing this improvment.
i've tested with 3 difffrent filters, a spare rj11 cable (router to filter cable think its rj11), with phone pluged in and not.
After seeing the improvment with all the diffrent setups i went back to the oringal setup i had but used the test socket and still get the improvment.
my default snr target must be 12db now as i just switched the router on and let it sync no tinkering with dmt to set snr
just see now if it holds at this sync speed now
heres a few of the dmt results from the setups and a couple of pictures of my master socket. when it says oringal setup on the dmt graphs it means that i have the rj11 cable going from the master socket in hall way though the wall into the living room but passes close the power socket thats why i tryed diffrent rj11 cable that was not near the power socket but still got same improvment with both.
cheers for the replys bright sparks
24-10-2008 4:31 PM
Or a fault in the drop wire, altered by moving it?
Nice improvement though, hope it stays stable.
24-10-2008 4:36 PM
do you mean the wire in the face plate connecting the two sockets on it.
24-10-2008 4:38 PM
(the multicore cable of which 2 cores are used for your signal - Orange and White is standard)
24-10-2008 4:43 PM
24-10-2008 4:56 PM
Cheers again oldjim for posting that dmt with same stats as mine as i would of not tested if i didnt see the diffrence in tone range.
I will post back in a few days to let you how i got on.
