need help in getting last 6 month's email
- need help in getting last 6 month's email
26-06-2008 12:05 AM
Hi, my primary HD failed, accidentaly formated secondary HD, lost everything(BooHoo). Is it possible to redownload say last 6 month's email? ps computer and email is up and running again, just need help in retrieving, thanks Danglese
Message 1 of 6
(1,202 Views)
5 REPLIES 5
Re: need help in getting last 6 month's email
26-06-2008 12:09 AM
Unfortunately, in general no.What email service do you use?
Message 2 of 6
(461 Views)
26-06-2008 2:34 AM
If you were using POP3 then no, you can't retrieve the old email as once it is downloaded to your PC it is deleted from the server so the only copy is on your PC.
If you used IMAP then the email remains on the server and you only view a copy of it. But it sounds like you were not using IMAP.
You should really look a some form of backup solution that if off your PC. e.g. and external USB drive and some backup software.
Message 3 of 6
(461 Views)
26-06-2008 3:08 AM
Whether or not emails remain on the server after download with POP3 depends on the settings chosen in Outlook Express (or whatever alternative you are using).
Message 4 of 6
(461 Views)
26-06-2008 10:47 AM
Get a or if you already have a maxtor or seagate drive they have a free program that allows you to copy a hard drive to a spare hard drive takes about 10 min I do mine every weekend.
Its called disk wizard and can be found on their web site
puddy
puddy
Message 5 of 6
(461 Views)
26-06-2008 6:39 PM
Thanks for the reply ppl, unfortunately it was pop3, and as I said I accidentaly formated my secondary HD...damn
Message 6 of 6
(461 Views)
