nas ftp server setting for Technicolor TG582n.
superscrew19
Hi all, i have looked through and can't find what i'm looking for.
I have the Technicolor TG582n and i have just bought a nas. I would like to access it as an ftp server. I have the nas set up as per instructions, but i cannot get the router to point to it.
I have spoken to plus.net and they say they don't/won't/can't support this. Does anyone have any idea how i get this to work?
The NAS is an ASUS NAS-M25, i have also order the static ip from plusnet.
Thanks in advance
Fixes: 54
Re: nas ftp server setting for Technicolor TG582n.
Probably not the answer you are hoping for but topic http://community.plus.net/forum/?topic=109688.msg938819 suggests the solution is to use a different router. Sad
David
Fixes: 50
IIRC the TG582n has an internal ftp server which might possibly get in the way of any access to the NAS ftp server. You could try disabling the internal service , from the web gui go to home->toolbox->content sharing
and make sure the ftp server is disabled.
Fixes: 10
Yes the TG582 has an FTP server. However if all you want to do is access the NAS from the LAN that shouldn't be a problem as the NAS will have a different IP address to the router. (Accessing the NAS from elsewhere on the internet would be a different matter!)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
