mybroadbandspeed - when is it going to be fixed?
- mybroadbandspeed - when is it going to be fixed?
Re: mybroadbandspeed - when is it going to be fixed?
30-03-2012 12:28 PM
[quote="Proposed caveat"]Sorry - My Broadband Speed is currently experiencing technical difficulty and may display misleading test results. Thanks for bearing with us
while we fix things.
30-03-2012 12:38 PM
It is pointless allowing speedtests to be done when the server is known to be overloaded, as the result is not only meaningless, but it also wastes capacity for everyone else doing tests at the same time - which might otherwise be OK.
30-03-2012 1:02 PM
Quote from: Bob What about changing the copy to read as follows then?
[quote="Proposed caveat"]Sorry - My Broadband Speed is currently experiencing technical difficulty and may display misleading test results. Thanks for bearing with us while we fix things.
Better!
30-03-2012 1:13 PM
Quote from: purleigh Surely it must be possible for the server(s) to detect when resource capacity is being reached, and then redirect any new connections to a holding page stating that the site is overloaded.
No. The problem is not with server load. It's mainly congestion further upstream on the network.
30-03-2012 10:25 PM
Quote from: jelv I've just looked at that topic and you didn't ever provide the information Andrew requested!
Edit: ... and looking at their speedtest results map I can see results for BT users up to full speed FTTC for BT users.
I certainly did by email at Andrew's request !
He suggested some tests using tbbmeter which I carried out. - he did provide me with an explanation but I don't remember the detail and seem to have deleted the email.
I suggest you read the whole thread.
30-03-2012 10:36 PM
Quote from: adagio He suggested some tests using tbbmeter which I carried out. - he did provide me with an explanation but I don't remember the detail and seem to have deleted the email.
Just found my last reply to Andrew
> I'll try and put something into the thread on the bbs later today,
> with a copy of your graphs to illustrate things if you dont mind.
> Andrew
Perfectly happy for you to make whatever use you like of the data.
Kind regards
David
I never saw anything appear in the thread.
04-04-2012 3:48 PM
This is now live.
13-04-2012 3:51 PM
Just had a look at MBS and noted that your warning text still appears. Right now it shows my download speed and upload speed actually compare well with the figures from my Belkin N router for once. Can I take it that work has been done or is it just a lucky fluke?
13-04-2012 3:54 PM
14-04-2012 5:16 PM
I did have hopes that the PITA could subside!!
15-04-2012 12:39 PM
Speed Test
19-04-2012 6:32 PM
20-04-2012 9:40 AM
21-04-2012 1:12 PM
16-05-2013 11:05 AM
Quote from: Bob
This is now live.
It has been spotted that this caveat has been removed. Presumably that means that all of the issues in the following have been resolved:
Quote from: Bob
Quote from: jelv Even on a 20CN line the results are half what they should be. The results it gives are seriously misleading. Until it is fixed it should be closed down and the link from the members centre redirected to some other tester that actually works!
There was a service status posted back in February during a period of time when the BT Speedtester was having problems. This was driving traffic to mybroadbandspeed.co.uk and putting the boxes under a lot of load.
Since then the boxes are no longer under load but there is definitely congestion upstream and we recognise that the speedtester is returning unreliable and misleading results.
As far as I've been able to tell, the problem stems from the fact that the platform needs scaling. In its current form it's not capable of handling the traffic. We probably need more boxes and the service needs switching to a higher capacity area of our network.
I suspect the bulk of the problem is due to ta bottle neck further upstream rather than an issue with the boxes themselves.
I have been discussing this with a few people in the office as we need to make a call on what to do. Either invest time/money into fixing the service, take it offline, or restrict it to Plusnet IP addresses or similar. We also need to consider what we do with all the linking that's done to the site from places like the Member Centre, Faults Checker and Help & Support pages.
I have serious concerns about taking offline completely because the site generates a hell of a lot of third party traffic and has a very desirable search ranking. Taking the site offline will damage this and harm any future plans to capitalise on the SEO traffic by branding/linking back from the site.
As soon as I know what's happening I'll be sure to let people know. I'll have a look at getting a Service Status out ...
