mybroadbandspeed.co.uk giving all unrealisitc results.
- mybroadbandspeed.co.uk giving all unrealisitc resu...
03-02-2010 10:13 AM
In the last hour I have tried using it 5 time times. Everytime I have tried it gives me results that are impossible.
Today 10:09 31531 kbps (3.94MB/s) 384 kbps (48kB/s) Share
Today 09:31 16178 kbps (2.02MB/s) 379 kbps (47.4kB/s) Share
Today 09:21 8037 kbps (1MB/s) 375 kbps (46.9kB/s) Share
Today 09:13 7758 kbps (970kB/s) 380 kbps (47.5kB/s) Share
Today 09:12 9966 kbps (1.25MB/s) 362 kbps (45.3kB/s) Share
My BT profile is 6500 and my PN is 6000. Could this be the problem?
speedtest.net is giving me stupid results aswell
Message 1 of 7
(2,733 Views)
6 REPLIES 6
Re: mybroadbandspeed.co.uk giving all unrealisitc results.
03-02-2010 10:42 AM
They should match but I wouldn't see that as a major factor in you varying D/L speeds.
Have you had a recent low sync event which caused a profile drop from which it is now recovering?
Message 2 of 7
(700 Views)
03-02-2010 10:54 AM
My profile was 6000 for the last few months. I restarted my router few days ago and it went into the 6500 profile barrier.
Some of the speedtest are outragous, 30000, 16000. I just wanted to know my speed, but these are way too unreliable. Any suggestions for a good speedtester?
This is off topic, but I don't see the point in starting a new thread. Is the usertools website automatically updated? because my exchange ETA fix time, just jumps forward after the date passes.
Message 3 of 7
(700 Views)
03-02-2010 11:35 AM
You could try a BT Speedtest or the one on TBB.
Re the usertools site, it is automatically updated, if the fix date has changed that'll have been changed in the update from BT Wholesale.
Message 4 of 7
(700 Views)
03-02-2010 9:25 PM
Dont feel alone, I am getting some bonkers speed results from mybroadbandspeedchecker.co.uk
Message 5 of 7
(700 Views)
03-02-2010 11:36 PM
I'm finding that mybroadbandspeed does not complete after the upload test - it sits on 100% with the upload speed gradually reducing. This started happening around the middle of January.
speedtest.net (which uses the same Ookla engine) works perfectly OK.
Message 6 of 7
(700 Views)
04-02-2010 10:44 AM
I've had no problems with either my broadband speed test or speed test.net. They both agree with each other and usually give a slightly higher speed than the BT Speed tester.
Message 7 of 7
(700 Views)
