my plusnet broadband dsl router
- my plusnet broadband dsl router
20-11-2016 12:53 PM
I believe that my router has just developed a problem,as the Ethernet connection has failed on NO1 Connector 2 3 & 4 are all Ok but the router is now making a scratchy sound,which my audio speakers connected to my PC are picking up.I have changed the Ethernet connection for a new cable but that makes no difference.I have plugged the PC with no ethernet into a different socket on the router and Ethernet is restored.I have also reset the router but the fault remains.I need the fourth socket as I have four PCs connected.Can anyone suggest what the problem may be? Thanks
Message 1 of 2
(454 Views)
1 REPLY 1
Re: my plusnet broadband dsl router
20-11-2016 2:54 PM
Message 2 of 2
(429 Views)
