my exchange is fibre live
- Re: my exchange is fibre live
03-06-2014 12:10 PM
How fast can you get me set up?
03-06-2014 12:15 PM
https://portal.plus.net/home-broadband/fibre/
03-06-2014 12:15 PM
If you go through the 'Product Change' in your Member Centre at http://portal.plus.net you will be given the option to input your availability and we'll do our best to arrange an engineer that suits you.
03-06-2014 12:22 PM
03-06-2014 12:33 PM
03-06-2014 12:35 PM
We have a new cabinet at the end of my raod for fibre its been there for 3 months now.
03-06-2014 12:38 PM
03-06-2014 12:44 PM
03-06-2014 1:16 PM
Quote its been there for 3 months now.
My cab was in place for nearly 6 months before it went live. Once PN receive a notification from BTOR thgat the cab is about to go live PN should let you know.
06-06-2014 2:50 PM
Quote from: Chris The best place for information and updates on dates is here https://www.dslchecker.bt.com/
is this website 100% correct?
I have checked my in-laws phone number and post code and I cant see its showing fibre for them but they have fibre? The results its shows are the same as when I enter my details yet if I go to BT's website to sign up it says I cant have fibre?
06-06-2014 2:55 PM
06-06-2014 2:56 PM
BT's customer service is a nightmare - at least PN's is up in Sheffield and Leeds. Infact this is one of the reasons that I cancelled with BT after hearing the India nightmares (and the HH5 problems) and came to Plusnet But it's each to their own.
06-06-2014 3:20 PM
Quote from: Dhaos Are you sure they have fibre and not virgin cable?
They have BT fibre.
06-06-2014 3:23 PM
Quote from: petecov44 Just so you know - BT won't be able to do it any quicker. BT is now just a retail ISP like PN - BT Openreach are the engineers and they won't give BT any preference - trust me I waited I had the same time frame when I ordered both. I think they aim for a max of 12 working days. It is well worth the wait though.
Understand that but its not really answering my question.
I was asking if that website was 100% correct as when I put my details into it I dont see any fibre options nor do I when I enter my in-laws deatils BUT they do have BT fibre already. I am currently using the BT website to keep an eye out for when I should be able to get it but this text I have done is making me think the website isnt right?
06-06-2014 3:29 PM
It's supposed to be, it's maintained by BTw and is used by all ISP's to determine if fibre is available.
Quote is this website 100% correct?
It has been known to have inaccuracies though but getting BTw to accept and get them corrected isn't an easy task I believe.
