turn on suggestions
my connection keeps randomly dropping and returning
- my connection keeps randomly dropping and returnin...
16-12-2013 2:23 PM
is it dropping ??
or is it this stupid loosing sync crap like it has done before ?
wired connection
wired connection
Re: my connection keeps randomly dropping and returning
16-12-2013 2:56 PM
Do you see the lights on the front of the router when you lose the connection? Do they stay the same or do any change?
We're not seeing many drops here, but it is possible that they are so quick they aren't being logged in which case I wouldn't expect them to cause huge issue as your router is connecting back straight away.
Are you in the master or test socket and does every phone socket in use have a filter on it?
Chris Parr Plusnet Staff |
16-12-2013 3:59 PM
no the lights dont really do anything different
im in the socket at the back with the front off.
i have 1 filter and 1 phone.
17-12-2013 1:48 PM
Hi totalguy,
I've just run a line test and can't see any obvious causes for any disconnections. If that's still proving to be an issue I'd recommend going through the steps at http://faults.plus.net
Adam
Adam
Adam Walker Plusnet Help Team |
17-12-2013 1:56 PM
done although it wasnt working kept telling me there was a problem
not the first time its done that.
19-12-2013 6:30 PM
seems ok today must have been a line glitch and the rain probably didnt help.
