my boadband is so slow?
goggz1888
just got plusnet the other day and so far im not to impressed.
i only use it for browsing the web and gaming (ps4)
i have noticed serious lag and have been unable to complete a game of fifa. it just disconnects from the servers.
anyway im supposed to be getting 7mb but its much lower than that constantly.
i have tried the ps4 hooked up and wireless and nothing is helping.
any ideas?
thanks
Re: my boadband is so slow?
The "My Broadband Speed" site is borked - don't rely on it.
Can you provide the information from this post to help the guys diagnose your issue?
As above - mybroadband speed is not accurate.
Fixes: 25
Goggz1888,
Welcome to PlusNET and the forums.
Can you please post your router seats here.  Instructions on how to do this an be found in the sticky links at the top of this forum.
goggz1888
Quote from: Townman
Goggz1888,
sorry i dont know if this is what you were looking for.......
Uptime: 1 day, 11:35:58
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [MB/GB]: 585.51 / 8.85
and my most recent speed test.......
Fixes: 62
Please run the BT speedtest and also report the current line speed - see here for details http://community.plus.net/forum/index.php/topic,96155.0.html
What does your exchange say about 21CN http://usertools.plus.net/exchanges/
goggz1888
Quote from: Oldjim
Download speed achieved during the test was - 6.75 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
Estimated line speed:
7Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-12-11 22:40:15
Current line speed:
7.15 Mb
exchange says
BT is reporting that some of the 20CN virtual paths at this exchange are not operating within BT Wholesale's planning guidance, although they are still operating within the product specification.
At busy times, your ADSL connection may operate at a reduced speed, although not all customers on your exchange may be affected. You should only contact support if there is no current ETA date set.
The ETA fix time is: 11 Feb 14
Record last updated: 31 Jan 14
thanks
Fixes: 25
Hopefully, you should see some improvements by Wednesday (a router restart might be required).  If no improvements are seen, then please post back here.
