moving to fibre , getting techicolor 582n ... need a manual
- moving to fibre , getting techicolor 582n ... need...
19-09-2012 10:22 AM
I have a thomson 585v8 right now.
In order to get it to work, I recall I spent several days ssh'd onto the box. Finally (this is from memory of a year ago)
I had to set up a static route ... this was because all my household is 10.0.0.0 address and the router is 192.168.x.y (forget exact setting)
I want to keep it this way as guest connect to 192.... network and internal machines are 10.... .... and between them I run my own box (proxy etc)
So my guess would be the 582n would need a similar static route ... does anyone have the real manual (cmds lines) do the web interface ?
Also anyone happen to know if the 525 shares the wireless N problem of the 585 ... it crashes if an N device connects?
Message 1 of 4
(867 Views)
3 REPLIES 3
Re: moving to fibre , getting techicolor 582n ... need a manual
19-09-2012 10:39 AM
Not certain if this one covers all firmware versions: http://wiki.aa.org.uk/index.php/File:TG582n_CLI_Guide_v1.0_public.pdf
Call me 'w23'
Message 2 of 4
(402 Views)
19-09-2012 12:38 PM
A very useful site ... thank for that , also found this there:
http://wiki.aa.org.uk/index.php/TG582N#Adding_Static-routes
Which shows how to add a static route , which is what I needed to do on 585v8 (and I'm guessing I'll need to do here)
Unfamiliar with this forum's netiquette ... I should tag your reply as "correct" and "useful" but I can't see a way ... anyhow many thanks ... amazing how hard it is to find out this stuff.
Message 3 of 4
(402 Views)
19-09-2012 12:42 PM
Quote from: vetterlein Unfamiliar with this forum's netiquette ... I should tag your reply as "correct" and "useful" but I can't see a way
You just did...
Quote from: vetterlein anyhow many thanks
You're welcome
Call me 'w23'
Message 4 of 4
(402 Views)
