moving network from Sky
- moving network from Sky
22-01-2015 9:09 PM
I've just got my TG582n router through the post and am waiting for
my broadband to be ready.
I'm currently with sky and my router has IP 192.168.0.1
Wireless is switched off on the sky router as its not very good.
My network has a few extra devices as well as the usual pc/phone etc: a NAS,
a wireless access point, a wireless "bridge" and a dd-wrt
router on a different subnet. I set up some of these with static IPs
I have a "DMZ server" set on the sky router in WAN setup as 192.168.0.254
and then ethernet cable from sky router to WAN port on the dd-wrt router.
The dd-wrt has static IP of 192.168.0.254, gateway is 192.168.0.1 and it's
internal IP is 192.168.1.1
I've noticed the plusnet one defaults to 192.168.1.254 so I'm wondering how best
to replace my sky router with minimum pain ? 🙂
The plusnet router has a sticker saying not to set it up before the "broadband's ready"
Can I just ignore this, connect it to my PC and change it's IP to that of the sky router
i.e. change it from 192.168.1.254 to 192.168.0.1
Then when the time comes just "hot swap" it with the sky router and everything will be fine ?
I don't want to void any warranty or fall fowl of terms and conditions!
Nick
Nick
Message 1 of 2
(573 Views)
1 REPLY 1
Re: moving network from Sky
23-01-2015 9:28 AM
As long as you don't connect it to your master socket you should be fine.
Turn it off after your done with the changes then when your order completes set it up and you should have no issues.
Message 2 of 2
(312 Views)
