microfilter extension lead
- Re: microfilter extension lead
13-07-2013 2:21 AM
13-07-2013 6:01 AM
The alternative would be to get a faceplate with the filter built-in. This would make your master socket stick out another couple of centimetres but would eliminate the dangling box that you find unsightly. Then you could continue to use the specially-purchase high-quality twisted-pair broadband-grade cable between the master socket and your modem that I presume you are using at present.
13-07-2013 2:00 PM
Replacing that short microfilter to socket lead in my current setup with a longer one seems to me the obvious way. But I remain unsure what type of lead would work as replacement.
13-07-2013 2:05 PM
13-07-2013 9:06 PM
14-07-2013 6:17 AM
Quote from: glocal But I remain unsure what type of lead would work as replacement.
To do as you originally asked you need a lead with a standard (BT) telephone plug on on end and a standard telephone socket on the other end. That is simply a telephone extension cable. The problem is that such cables typically use low-grade wiring ill-suited to broadband so your broadband speed might suffer a little. Don't get one any longer than you actually need.
14-07-2013 2:36 PM
14-07-2013 7:48 PM
14-07-2013 8:27 PM
14-07-2013 9:35 PM
14-07-2013 11:01 PM
14-07-2013 11:14 PM
14-07-2013 11:35 PM
15-07-2013 11:41 AM
15-07-2013 12:45 PM
http://www.clarity.it/xcart/product.php?productid=16227&cat=254&page=1
