may as well use dial up *sighs*
warbleeder
i joined plus net just over 2 week ago and should be on a 8 meg line ive been having constant connection issues slow downloads.
over the last two weeks ive been telling plus net theres a fault for them to tell me there isnt Cry (im currently plugged into test socket) ive also tried 2modems / 2 modem cables / 4 filters / all from plusnet ... ive just done speed checks and got the following
Today 22:03  179 kbps (22.4kB/s)  132 kbps (16.5kB/s)  Share
Today 22:01 686 kbps (85.8kB/s) 120 kbps (15kB/s) Share
Today 22:00 240 kbps (30kB/s) 285 kbps (35.6kB/s) Share
Today 21:59 217 kbps (27.1kB/s) 215 kbps (26.9kB/s) Share
Today 21:58 262 kbps (32.8kB/s) 164 kbps (20.5kB/s) Share
DIAL UP HERE I COME Sad( Cry
warbleeder
Re: may as well use dial up *sighs*
when i contacted plus net last week they informed me the connection had dropped (disconnected) 15 times over the week the tech also quoted (it isnt normal)
when i spoke to them today they told me it dropped 11 times over the last week :s now please tell me this is my problem
paulpicks21
Something not right there bud.
What is the expected speed for your line?
Paul
Fixes: 50
What does a BT Speed test say http://www.speedtester.bt.com/
Customer and Forum Moderator.
warbleeder
Download speedachieved during the test was - 774 Kbps
Additional Information:
Assured Rate IP profile on your line is - 7150 Kbps
its jumping badly and dont seem to wanna go above 1 meg :S
7 times ive now tryed to download directx and its lost connection Sad
Fixes: 32
Hi warbleeder,
I've just updated the fault ticket on your account. Please check our response and we will update you again when BT come back to us.
 Adam Walker
