max uploads on fixed lines?
mattstead
As BT can't sort out my stability issues  / the noise on the line, I've regrettably opted to go on a 1 meg fixed line. So my IP profile is 1000K , and my the download is 912k, and the upload is 288k. The thing is, before the line was fixed I had an upload of about 400K. Why would fixing the IP profile reduce the upload, when the speed was still less than the 1000k profile?
1 REPLY
Fixes: 62
Re: max uploads on fixed lines?
It hasn't fixed your IP profile it has moved you to a fixed rate product and unfortunately that has the 288k upload speed as it isn't MaxDSL
