@matthewwheeler VPN ISSUE
- @matthewwheeler VPN ISSUE
20-04-2024 11:19 AM
Found many posts when trying to connect to Cisco secure client, I’ve enabled port clamping, and turned my firewall settings to low. I connect to vpn before logging into windows, when my desktop opens it disconnects the vpn doesn’t allow me to reconnect. The servers aren’t talking to each other. I’ve read somewhere that we need to do something with dtsl can you please private message?
Message 1 of 2
(623 Views)
1 REPLY 1
Re: @matthewwheeler VPN ISSUE
20-04-2024 3:12 PM
Hi @Charlo898, thanks for getting in touch. You can try and add the Static IP which sometimes resolves these issues, there will be a one off charge of £5 though. Just head over to your member centre and you'll be able to add this on.
Any trouble doing this, just let me know ![]()
Message 2 of 2
(577 Views)
