mailbox doesn't download to Outlook Express
- mailbox doesn't download to Outlook Express
14-08-2007 10:48 PM
I set up a couple of mailboxes today. One works fine & sends emails to OE or Outlook if I want. However the others just won't work. OE keeps throwing up that box asking for user name & password. I've set up the accounts in exactly the same way in OE & am tearing my hair out!
One point which may be relevant - I had mailboxes set up with the same names as the new ones which won't work, but I hadn't used them for years & they were archived. So I deleted them & then set up new ones with same names - could this be problem?
Message 1 of 9
(2,752 Views)
8 REPLIES 8
Re: mailbox doesn't download to Outlook Express
14-08-2007 10:51 PM
How long ago did you create the new mailboxes as it can take 4 or more hours before they become active. In some cases I have had to wait 24 hours before they work.
Message 2 of 9
(1,028 Views)
14-08-2007 11:09 PM
They were all set up this afternoon - one after the other. Thats why I can't understand that 1 works, but the others don't.
Message 3 of 9
(1,028 Views)
14-08-2007 11:17 PM
Can you login to the mailbox using webmail? If not wait a while longer (i.e. 'til tomorrow) and try again.
Message 4 of 9
(1,028 Views)
14-08-2007 11:39 PM
I've looked at webmail, but can't see anything & to be honest I don't know how to find specific mailbox in webmail - so I'm not sure I'm checking up properly.
Message 5 of 9
(1,028 Views)
15-08-2007 12:06 AM
Login to webmail by entering username+mailboxname in the Name box and the password that goes with that mailbox in the Password box.
David
Message 6 of 9
(1,028 Views)
15-08-2007 12:28 AM
The ones that don't work come up with unknown user or password incorrect.
The one that works though was literally set up 30 seconds before!
Message 7 of 9
(1,028 Views)
15-08-2007 12:31 AM
As I said earlier, some can take longer to set-up - why I have no idea - but they do.
Try again in the morning with webmail.
Message 8 of 9
(1,028 Views)
15-08-2007 1:05 AM
Thanks for your help. I actually got so frustrated I deleted mailbox & reset it up. It worked in about 30 seconds flat!! Computers who says they don't have a mind of their own!
Message 9 of 9
(1,028 Views)
