low speed (again) and inscreased SNR
- low speed (again) and inscreased SNR
24-07-2010 2:02 PM
Uptime: 6 days, 7:45:47
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 9,248
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 13.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 19.0 / 36.5
SN Margin (Up/Down) [dB]: 27.5 / 10.0
Loss of Framing (Local/Remote): 23 / 0
Loss of Signal (Local/Remote): 6 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 118 / 0
FEC Errors (Up/Down): 0 / 674,406
CRC Errors (Up/Down): 0 / 2,485
HEC Errors (Up/Down): 0 / 2,142
Re: low speed (again) and inscreased SNR
24-07-2010 2:30 PM
28-07-2010 1:30 PM
28-07-2010 2:02 PM
28-07-2010 3:29 PM
28-07-2010 3:41 PM
I'd like PN to get BT to reduce my noise margin back to 6dB - but they have a script to generate a "why we know you wouldn't want that".
28-07-2010 4:12 PM
29-07-2010 11:11 AM
29-07-2010 12:21 PM
29-07-2010 12:32 PM
29-07-2010 2:12 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
6476 Kbps
0 Kbps 21000 Kbps
Max Achievable Speed
Download speed achieved during the test was - 6476 Kbps
For your connection, the acceptable range of speeds is 2000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :11815 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 10000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.51:21.4:65.09 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
14/06/10 at 13:34
Download Speed
6542 Kbps
0 Kbps 7150 Kbps
Download speed achieved during the test was - 6542 Kbps
For your connection, the acceptable range of speeds is 1000-7150 Kbps.
Your DSL Connection Rate :9248 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 8000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.57:24.78:61.64 (SBE:NBE:PBE)
Please visit FAQ section if you are unable To understand the test results.
@1324 on 28/07/2010
Can someone from PN please explain this and tell me if the download speed will ever return to 10meg previously seen or is the 6.5meg download speed the best I can expext on this service
29-07-2010 2:58 PM
29-07-2010 3:22 PM
29-07-2010 3:34 PM
29-07-2010 3:41 PM
