low moise margin causing constant resyncs
- Re: low moise margin causing constant resyncs
16-09-2010 6:00 PM
I seem to be getting connection drops several times a day, please could someone from plusnet take a look at the stats for my line and see if there is anything suspect going on?
Uptime: 0 days, 0:03:20
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 447 / 13,693
Output Power (Up/Down) [dBm]: 12.0 / 21.0
Line Attenuation (Up/Down) [dB]: 19.0 / 34.0
SN Margin (Up/Down) [dB]: 20.0 / 3.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 23 / 0
Loss of Signal (Local/Remote): 37 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 342 / 0
FEC Errors (Up/Down): 0 / 28,226
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 1,441 / 0
Tony
Re: Constant resyncs
17-09-2010 10:50 AM
These are the drops we're seeing here, if you are seeing more than that then maybe you can connect via ethernet if you are using wireless, to see if that's the cause.
I notice there are consistent drops at 8am and 11pm. Is there anything you think might cause this?
Jojo
17-09-2010 2:36 PM
I am currently connected to the extension socket, I will plug into the master socket for a few days to see if i still get dropouts.
Tony
17-09-2010 4:51 PM
It may not be something you do, it may be your central heating etc, anything that could be on a timer etc. It may just be a coincidence . As far as the extension goes, there will always be less trouble when you are not using one.
Jojo
20-09-2010 8:40 PM
If it keeps dropping like this then i might end up on a banded profile, is there anyway to fix the noise margin at around 6db? would line training help?
Tony
21-09-2010 11:55 AM
I have applied what's called a soft override which has set the downstream target SNR to 6dB for you.
Hope that helps
Jojo
21-09-2010 11:59 AM
Tony
21-09-2010 12:09 PM
Jojo
21-09-2010 7:18 PM
It doesnt seem to have fixed it, the connection is still dropping, here are the stats:
Uptime: 0 days, 0:30:05
Bandwidth (Up/Down) [kbps/kbps]: 444 / 14,333
SN Margin (Up/Down) [dB]: 22.5 / 3.0
Loss of Signal (Local/Remote): 2 / 0
Error Seconds (Local/Remote): 56 / 0
FEC Errors (Up/Down): 0 / 757,354
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 1,475 / 2
Could it just be an issue with thomson 585 routers? would it be worth trying a different brand or is there still a fault on the line?
Tony
21-09-2010 7:52 PM
Quote from: rockfall
Could it just be an issue with thomson 585 routers? would it be worth trying a different brand or is there still a fault on the line?Thanks Tony
Pairing the router Chipset to the exchange is definitely worth a try.
Texas Instrument chipset (TI) at the exchange (TSTC) so a TI -AR7 based router would be good test bed.
Something like a Netgear DG834g (Version 1, 2 and 3 have AR7 Chipset, not version 4) or a ZyXEL Prestige 660 are a cheap & easy options of feebay.
(Some more AR7's on Wiki http://en.wikipedia.org/wiki/TI-AR7 )
f9o
21-09-2010 11:50 PM
That's stumped me that has. I'll contact BT get to work in the morning and try to find out how come it's still 3
Jojo
22-09-2010 9:06 AM
Apparently it can take up to 24 hours to take effect, so when they told me they'd done it I think they meant it was ordered. Let me know what it's like a bit later and we'll take it from there.
Jojo
22-09-2010 11:54 AM
Many thanks
Tony
23-09-2010 11:57 AM
Doesn't look like it's taken effect yet so I'm going to chase it up for you today.
Jojo
05-11-2010 10:53 PM
It was ok for the first few days but the noise margin is still going down to 0db and it's dropping the connection. Is there anything else that could be done?
Tony
