low dload speed
fastconnection
low dload speed
Hi Plusnet type folks
We have been having some building works here and the router has been off/on off on off on..I think you get the picture. Of course now the dload speed is way down. I suppose my ip profile is now broken! The router is now on 24/7. Will the IP prof reset after a while or do I have to do something (anything)? Many thanks
Re: low dload speed
The DLM has set your line to 1Mb/s. We'd need to see your connection stable over the next 24-48 hours and we'd be able to place a SNR reset to rectify this.
fastconnection
Re: low dload speed
Hi Chris
Thanks for that. Should I contact you again in 48hours or will it happen auto?
Re: low dload speed
You can give us a nudge on here or raise a fault via http://faults.plus.net and we'll get that arranged.
fastconnection
Re: low dload speed
nudge nudge!
Router is now perm on so could you do the reset please?
Many thanks!
fastconnection
Re: low dload speed
anyone home?  Wink
Fixes: 62
Re: low dload speed
No - the staff are normally only on here during normal office hours
fastconnection
Re: low dload speed
Fair enough. Got a nice phone call this evening though and they are on the case..not bad eh?
P.S. you're not really as old as those hills are you?
Re: low dload speed
Really hope this morning's engineer visit gets things sorted for you, please let us know how it goes.
Fixes: 62
Re: low dload speed
Quote from: fastconnection
Nearly but not quite
