lots of work done on the line am i on the right profile?
psyfy
Hello community, i first joined plusnet after Bethere sold out to Ughhh SKY,
unfortunately i am quite rural and when i first moved in the phones barely worked 5 engineers later 2 new masts and a whole lot of disruption i now have a grade A line, my speed has increased as a result, before i would be lucky to get a stable 2mb connection for more than 20mins at a time.
But i believe my line is now capable of a little more than what im getting.
this is what im currently getting, my speed has slowly been increasing, but seems to stop at around 6000/832 sync speed.
Type Interleave Path
  Status SHOWTIME
Downstream Upstream
  Data rate(Kbps)
5664Kb/832Kb
  Noise Margin
6/10
  Output power(dBm)
124/200
  Attenuation(dB)
49/31
am i stuck on a low end profile?
can i be tried on the middle tier?
kind regards psy.
Fixes: 165
Re: lots of work done on the line am i on the right profile?
Your line is performing pretty much where I'd expect speed wise from the reported attenuation, it's also well above the estimates of 1-3.5Mb! At the moment your line is on what's known as ADSL1 on 21CN, I'd like to move you to ADSL2+ on 21CN, this might give you a very slight increase in speed. It's free to do this and it should complete tomorrow.
I wouldn't expect drastic changes as your line is pretty much at the limits of what I'd expect.
 Chris Parr
 Plusnet Staff
psyfy
as far as im aware the routing to the exchange has been shortened quite a lot. i look forward to seeing if moving over to adsl2+ increases it, i only just became aware i was still stuck on the old limited system. it would certainly be nice to have a meg upstream again.
many thanks.
Fixes: 165
Let us know how the line stats are looking tomorrow after the upgrade has completed, hopefully there'll be some improvement.
 Chris Parr
 Plusnet Staff
psyfy
  Status SHOWTIME
Downstream Upstream
  Data rate(Kbps)
5688Kb 840Kb
  Noise Margin
6 4
  Output power(dBm)
128 197
  Attenuation(dB)
55 28
I see a slight improvement over all most notably the noise margin, speed seems to be slowly creeping up. i may be imagining this though, can you confirm the switch has been made.
many thanks Psy.
Fixes: 165
Yep, that's showing as complete now. Let us know if you have any issues with this.
 Chris Parr
 Plusnet Staff
