lots of work done on the line am i on the right profile?
- Re: lots of work done on the line am i on the righ...
07-01-2015 1:54 PM
Hello community, i first joined plusnet after Bethere sold out to Ughhh SKY,
unfortunately i am quite rural and when i first moved in the phones barely worked 5 engineers later 2 new masts and a whole lot of disruption i now have a grade A line, my speed has increased as a result, before i would be lucky to get a stable 2mb connection for more than 20mins at a time.
But i believe my line is now capable of a little more than what im getting.
this is what im currently getting, my speed has slowly been increasing, but seems to stop at around 6000/832 sync speed.
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps)
5664Kb/832Kb
Noise Margin
6/10
Output power(dBm)
124/200
Attenuation(dB)
49/31
am i stuck on a low end profile?
can i be tried on the middle tier?
kind regards psy.
Status SHOWTIME
Downstream Upstream
Data rate(Kbps)
5664Kb/832Kb
Noise Margin
6/10
Output power(dBm)
124/200
Attenuation(dB)
49/31
kind regards psy.
Message 1 of 6
(1,214 Views)
5 REPLIES 5
Re: lots of work done on the line am i on the right profile?
07-01-2015 2:15 PM
Your line is performing pretty much where I'd expect speed wise from the reported attenuation, it's also well above the estimates of 1-3.5Mb! At the moment your line is on what's known as ADSL1 on 21CN, I'd like to move you to ADSL2+ on 21CN, this might give you a very slight increase in speed. It's free to do this and it should complete tomorrow.
I wouldn't expect drastic changes as your line is pretty much at the limits of what I'd expect.
Message 2 of 6
(494 Views)
07-01-2015 2:19 PM
as far as im aware the routing to the exchange has been shortened quite a lot. i look forward to seeing if moving over to adsl2+ increases it, i only just became aware i was still stuck on the old limited system. it would certainly be nice to have a meg upstream again.
many thanks.
many thanks.
Message 3 of 6
(494 Views)
07-01-2015 2:24 PM
Let us know how the line stats are looking tomorrow after the upgrade has completed, hopefully there'll be some improvement.
Message 4 of 6
(494 Views)
09-01-2015 1:48 PM
Status SHOWTIME
Downstream Upstream
Data rate(Kbps)
5688Kb 840Kb
Noise Margin
6 4
Output power(dBm)
128 197
Attenuation(dB)
55 28
I see a slight improvement over all most notably the noise margin, speed seems to be slowly creeping up. i may be imagining this though, can you confirm the switch has been made.
many thanks Psy.
Status SHOWTIME
Downstream Upstream
Data rate(Kbps)
5688Kb 840Kb
Noise Margin
6 4
Output power(dBm)
128 197
Attenuation(dB)
55 28
many thanks Psy.
Message 5 of 6
(494 Views)
09-01-2015 4:53 PM
Yep, that's showing as complete now. Let us know if you have any issues with this.
Message 6 of 6
(494 Views)
