lost net for 5 mins
scootie
lost net for 5 mins
just lost internet connection at about 00.30 logged into router and had no ip tried to Auth again and wouldnt let me for 5-10mins.
any one else or iam just special?  Smiley
i see alot of auth problems on the service status and some load balencing work to be done but these all seem geared towards 20cn and the pcl-ag04 gateway
Fixes: 63
Re: lost net for 5 mins
No BT Planned Maintenance Work is down on the Plusnet list for today and I think you are right that network balancing should not affect 21CN connections. So no obvious reason for the problem you experienced (I'm not on WBMC and the IPSC trial won't let me through the door). The Plusnet website is due to go down from 2AM to 4AM today.
David
David
James
Hiya,
The authentication problems were fixed the other day and the balancing work won't have affected THN-Ag2 (ADSL2+ pipe).
There don't appear to be any acknowledged outages in your area either.
I'm afriad I'm going to have to put it down as "one of those things".
