looking for better router
adeym0n
hi im looking for a better router I have fibre broadband and was wondering if it was possible to use another router say like the new bt home hub for better wifi range
or would it be better buying one of the wifi plugs that extends the range
thanks
ade
thomasjc1
Re: looking for better router
It depends on what you want to spend i ve got the asus rt-n66u like many others on here and its brilliant but its around the £100 mark
darklight
I also got a rt-n66u, you can't got wrong with this router, very very good wifi range.
